trishacooks
#1 Posted : Thursday, November 11, 2010 4:04:14 AM(UTC)
trishacooks
I started noticing my oven takes a long time to heat to temp. So I tried using the convection but that is taking long also.Can this be repaired? :confused:
Joe / APP Team
#2 Posted : Thursday, November 11, 2010 6:27:24 AM(UTC)
Joe / APP Team
Trisha,
Yes it's repairable.
You could probably do it yourself, and save a lot of money.
Do us a favor and select the Broil cycle, and tell me if the oven heats ?
I'm guessing(hoping) you have a weak bake burner igniter.
Part number: AP4012072
You may also want to check the bake burner and igniter operation yourself ?
(remove the oven bottom panel, and you'll have access to the burner assembly)
It should take 30 to 60 seconds after you make a bake selection, to ignite the gas, on the burner, longer than that, you've got a weak igniter.
Good Luck,
