I started noticing my oven takes a long time to heat to temp. So I tried using the convection but that is taking long also.Can this be repaired? :confused:
Originally Posted by: trishacooks  I started noticing my oven takes a long time to heat to temp. So I tried using the convection but that is taking long also.Can this be repaired? :confused: Trisha, Yes it's repairable. You could probably do it yourself, and save a lot of money. Do us a favor and select the Broil cycle, and tell me if the oven heats ? I'm guessing(hoping) you have a weak bake burner igniter. Part number: AP4012072
You may also want to check the bake burner and igniter operation yourself ? (remove the oven bottom panel, and you'll have access to the burner assembly) It should take 30 to 60 seconds after you make a bake selection, to ignite the gas, on the burner, longer than that, you've got a weak igniter. Good Luck, :) :) :)
