2 Pages12>
badercrew
#1 Posted : Wednesday, November 10, 2010 9:48:01 AM(UTC)
badercrew
help please. i have a jenn aire double wall oven electric # jjw9627cas. i just replaced the touch panel and clock/timer. that is working fine and nice to see the display again. the problem is the top oven displays the temp but the food is not cooking right and it doesnt feel as hot as the bottom oven with cooks fine. any ideas ? all your help is appriciated....
thanks,
ira
#2 Posted : Wednesday, November 10, 2010 1:25:23 PM(UTC)
Place the oven thermometer in the middle of the upper oven cavity. Set the Bake on 350 degrees and do not open the oven door for about 10 minutes after the oven preheated. Open the oven door, check the temperature and post the result.
badercrew
#3 Posted : Friday, November 12, 2010 5:11:10 PM(UTC)
badercrew
thanks gene,
here are the results : ( with thermometer hanging in the middle of the oven )
after 10 minutes at 350 bake the control panel read 165 the thermometer read 100..
after 20 minutes the control panel read 235 and the thermometer read 150...
after 30 minutes the panel read 260 and the thermometer read 180...
after 40 minutes the panel read 285 and the thermometer read 210...
it seems the bake element is not getting hot...
thanks for your help in advance
ira
#4 Posted : Monday, November 15, 2010 4:29:09 PM(UTC)
ira,
Did the Bake heating element get red while it was ON?
If not, remove the Bake heating element, disconnect the wires from its terminals and the heating element for continuity.
If the heating element is open, replace the heating element.
If the heating element is fine, replace the control board.
- The Bake heating element Part number: AP4089972
- The control board Part number: AP4089375
badercrew
#5 Posted : Tuesday, November 16, 2010 6:44:34 AM(UTC)
badercrew
thanks gene...i am going to order the element as i replaced the control panel last week and the oven wasnt heating prior to that....at least with the new panel i can see how long its taking...thanks again and i will let you know the outcome after the element goes in....need both ovens as turkey day is fast approaching.
ira
badercrew
#6 Posted : Thursday, November 18, 2010 5:06:11 PM(UTC)
badercrew
gene,
change out the bake elementand still not heating up. after about 45 minutes the panel read 350 but the oven thermometer read only 280. any other suggestion ?
thanks,
ira
#7 Posted : Thursday, November 18, 2010 5:47:21 PM(UTC)
Do not open the oven door while the test is running. Open the oven door about 10 minutes after it beeped preheated to read the temperature.
P.S. Did the Bake heating element get red while the oven was on?
badercrew
#8 Posted : Friday, November 19, 2010 9:42:43 AM(UTC)
badercrew
gene,
i didnt open the door until after it hit 350...and i am not seeing the element getting red...something is getting the oven warm not the element...would love to return it as that wasnt the problem...just would like to figure out what is wrong with the oven and get it working....
thanks again
ira
#9 Posted : Friday, November 19, 2010 2:01:17 PM(UTC)
You said you replaced the control panel. Which part did you cal "control panel" #1 or #3 on the diagram?
You have to have a simple multimeter to perform the troubleshooting to avoid guessing and replacing unneeded parts.
badercrew
#10 Posted : Friday, November 19, 2010 5:19:47 PM(UTC)
badercrew
gene,
i replaced both 1 & 3...my clock had been out for a while so i finally replaced it and when i did the touch pad went bad so i replaced that too....the top oven was not heating for a while and now after replacing the bake element i still dont have the oven heating up right. what else could it be ? i hate to call someone in if its someyhing i can do myself.
thanks again,
ira
2 Pages12>
