Klaus
#1 Posted : Monday, November 3, 2008 2:40:59 PM(UTC)
Klaus
how do I access the drive belt to change? Motor runs, but drum does not spin, so I assume a drive belt is broken.
Drags1998
#2 Posted : Monday, November 3, 2008 4:20:54 PM(UTC)
Drags1998
Lift the top, remove the front, remove the drum, also check the IDLER, and the REAR BEARING!!!
Maytag LA506 - Will Not Agitate, Burns Drive Belt (Washer Repair)
by tjg79 9/17/2021 8:59:35 PM(UTC)
Amana Washing Machine Drive Belt Slipping after Belt and Idler Spring replacement (Washer Repair)
by tjensen47 11/7/2013 9:15:11 AM(UTC)
Frigidaire Washer Won't Spin after replacing drive belt (Washer Repair)
by Shindigit 5/4/2013 10:54:15 AM(UTC)
Drive Belt Replacement (Washer Repair)
by mzulkoski 6/27/2012 12:49:20 PM(UTC)
Drive Belt Replacement (Dishwasher Repair)
by TerryNi 3/7/2012 1:18:48 PM(UTC)
drive belt replacement (Washer Repair)
by RodE 1/22/2012 1:16:04 PM(UTC)
by granitecrusher 12/24/2011 4:51:13 AM(UTC)
by cooldre 11/11/2011 3:16:22 PM(UTC)
Maytag Atlantis Drive Belt Replacement ??? (Washer Repair)
by oaktree 9/1/2011 1:44:35 PM(UTC)
maytag washer drive belt? (Washer Repair)
by nathan79 8/13/2011 8:41:40 AM(UTC)
Automotive Belt For Drive Belt?? (Washer Repair)
by LI Mark 7/26/2011 2:08:10 PM(UTC)
Drive Belt Wheel is wobbly (Washer Repair)
by Bonkers 7/15/2011 6:33:45 PM(UTC)
Replacing drive belt on pulley on gas dryer (Dryer Repair)
by Captain5 4/7/2011 4:17:46 PM(UTC)
Drive belt Replacement (Washer Repair)
by gary2kb 3/13/2011 6:19:51 AM(UTC)
Replacing drive belt (Washer Repair)
by vsealv 2/28/2011 12:49:08 PM(UTC)
