AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag Performa Washer Leaking From Bottom While Filling
Model # LAT2500AAE
The title says it all. It's not a massive leak, but I want to fix it. The washer leaks as it is first fills, and refills for the rinse. I don't think it's leaking while agitating or spinning, but I'm not 100% sure. Thanks for any insight.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: mjones61 Model # LAT2500AAE
The title says it all. It's not a massive leak, but I want to fix it. The washer leaks as it is first fills, and refills for the rinse. I don't think it's leaking while agitating or spinning, but I'm not 100% sure. Thanks for any insight. Check this diagram. Cabinet replacement parts for MAYTAG LAT2500AAE Washer - Top Loading | AppliancePartsPros.comCheck the parts in the area labeled "23" (top left). I've seen hoses leak and I've seen the injector part 21 get limed up and cause the water to spray off to the side or at an odd angle.
I failed to mention that the water had a little soap in it while filling for the rinse cycle.
Groups: Expert
Originally Posted by: mjones61 I failed to mention that the water had a little soap in it while filling for the rinse cycle. Run the washer. Wait until you see it leaking, shut it off, then pull the front off the cab. Check up above the transmission and see if the seal and bearing in the center is wet. If it is you will need Part Number: AP4390013 .
Washer Repair
