mjones61
#1 Posted : Sunday, November 7, 2010 11:00:15 AM(UTC)
mjones61
Model # LAT2500AAE
The title says it all.
It's not a massive leak, but I want to fix it.
The washer leaks as it is first fills, and refills for the rinse.
I don't think it's leaking while agitating or spinning, but I'm not 100% sure.
Thanks for any insight.
ThatGuy
#2 Posted : Monday, November 8, 2010 1:38:59 AM(UTC)
ThatGuy
Groups: Expert
United States
Originally Posted by: mjones61 Go to Quoted Post
Model # LAT2500AAE
Check this diagram. Cabinet replacement parts for MAYTAG LAT2500AAE Washer - Top Loading | AppliancePartsPros.com
Check the parts in the area labeled "23" (top left). I've seen hoses leak and I've seen the injector part 21 get limed up and cause the water to spray off to the side or at an odd angle.
mjones61
#3 Posted : Thursday, November 11, 2010 9:17:52 AM(UTC)
mjones61
I failed to mention that the water had a little soap in it while filling for the rinse cycle.
ThatGuy
#4 Posted : Friday, November 12, 2010 12:41:14 AM(UTC)
ThatGuy
Groups: Expert
United States
Run the washer. Wait until you see it leaking, shut it off, then pull the front off the cab. Check up above the transmission and see if the seal and bearing in the center is wet. If it is you will need Part Number: AP4390013 .
Guest (5)
