The Oven will not heat. The control panel appears to work fine. The clock, Bake, Broil, and Light controls are reflected on the lighted display. The light in the oven works when the panel is pushed. The Oven will not get hot at all. Neither Bake or Broil.
I shut off the power. I opened up the control panel to make sure all wires were connected from the panel. Turned the power on. No difference. I was going to replace part number WB27K5273 (the oven control box) but I can't find the part. Do you recommend a new replacement part? Can I change it myself? Is there something else to try?
The part number from this site is AP3141629. You may want to remove the rear panel and look for a chewed or broken wire first.
Nat
