I have a new GE GFSS6KEXSS on which i would like to be able to selectively disable the door open sensors on the fridge & freezer (the sensor which shuts the lights & fans when the door is ajar). It does not have the plunger-style sensor. I beleive it has some sort of magnetic sensors. Any ideas? Thanks.
If it is under a year old don't do anything to it or you could void your warranty.
Nat
I am aware of the warranty issues, as well as the potential for inefficient operation and a shorter compressor lifetime.
