carl pettit
#1 Posted : Thursday, November 4, 2010 1:21:17 PM(UTC)
carl pettit
i am replacing the damper kit and it tells me i need a rubber adhesive i was wondering if it is a special kind or will any rubber adhesive work
#2 Posted : Friday, November 5, 2010 3:32:06 AM(UTC)
No high temperature there under the tranny so any good rubber cement will work, just make sure it is of good quality and fast setting.
applianceman
#3 Posted : Friday, November 5, 2010 8:25:47 AM(UTC)
applianceman
[FONT='Times New Roman']I always used super weather strip adhesive, which works well. It is the glue used to put door gaskets on cars as far as I know. You should be able to get it at your local car parts store. [/FONT]
damper kit (Washer Repair)
by carl pettit 11/4/2010 1:23:06 PM(UTC)
Damper Kit (Refrigerator & Freezer Repair)
by rebecca griesemer 8/13/2009 4:56:03 PM(UTC)
