c.w. korger
#1 Posted : Thursday, October 30, 2008 7:55:11 PM(UTC)
c.w. korger
the digital clock when set to bake shows the temp desired but starts at 100 on the clock and after a few seconds blanks out and the burners never come on.
v2k04
#2 Posted : Thursday, October 30, 2008 10:30:44 PM(UTC)
v2k04
Thats a Roper built range Those controls will display an F code when the sensor is bad but if the sensor checks good the control would be the problem
c.w. korger
#3 Posted : Friday, October 31, 2008 7:26:53 PM(UTC)
c.w. korger
Forgive My Ignorance I Do Not Find A F Code Where The Temp Reads 100 And Begins To Go Up As Burners Come On Normally . Now It Simply Goes Out The Burners Never Come On And Clock Returns To Clock.thanks For Your Responce I Am Gratefull.
#4 Posted : Saturday, November 1, 2008 5:10:54 PM(UTC)
Most likely the problem is a bad control board aka a clock. This part has to be replaced.
- The part number for the clock is AP2025145
P.S. This oven made by GE.
