the digital clock when set to bake shows the temp desired but starts at 100 on the clock and after a few seconds blanks out and the burners never come on.
Thats a Roper built range Those controls will display an F code when the sensor is bad but if the sensor checks good the control would be the problem
Forgive My Ignorance I Do Not Find A F Code Where The Temp Reads 100 And Begins To Go Up As Burners Come On Normally . Now It Simply Goes Out The Burners Never Come On And Clock Returns To Clock.thanks For Your Responce I Am Gratefull.
Most likely the problem is a bad control board aka a clock. This part has to be replaced. - The part number for the clock is AP2025145 Gene. P.S. This oven made by GE.
