POtt
#1 Posted : Thursday, October 30, 2008 4:22:45 PM(UTC)
POtt
The part of the upper feed tube that rests on the ceiling of the dishwasher cavity is hanging down a bit and it hits the upper rack when it is in the top most position. Is this piece supposed to be attached? We haven't had this problem until recently.
v2k04
#2 Posted : Thursday, October 30, 2008 4:33:21 PM(UTC)
v2k04
I dont recall that it does it may have gotten warped from the heat and needs replaced I know they come out easy enough
billne
#3 Posted : Thursday, November 20, 2008 4:55:17 AM(UTC)
billne
I have the same problem with an SHI6805UC/U12. The upper feed tube is hanging down from the top groove it is supposed to sit in, stopping the upper basket from pulling out. The tube cost $51 to replace. I was thinking of using double stick or metal tape to hold it up. Any thoughts?
v2k04
#4 Posted : Thursday, November 20, 2008 5:59:49 AM(UTC)
v2k04
you shouldn't need anyof that with a replacement if something is broke inside the stainless tank holding it would be covered under the 10 or 20 year tub warranty tapes or glue or any adhesive wouldn't hold to the high temps it gets when calling for heat
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
Bosch Dishwasher skips to "clean" even after part replacement (Dishwasher Repair)
by Guest 6/20/2023 5:17:19 PM(UTC)
Bosch dishwasher SHX65T55UC/07 not dispensing soap unless in "Express" mode (Dishwasher Repair)
by callussun 4/19/2023 9:46:00 PM(UTC)
Bosch dishwasher shem3ay 55n/25 (Dishwasher Repair)
by Guest 3/23/2023 5:18:20 AM(UTC)
Bosch dishwasher only drains on reset and specific cycle (Dishwasher Repair)
by vusedad 10/18/2022 8:54:46 AM(UTC)
Bosch dishwasher model SMV41D10EU/48 Not working (Dishwasher Repair)
by adriandlb 10/7/2022 12:18:47 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
Bosch Dishwasher Model SHPM65Z56N (Dishwasher Repair)
by Guest 7/8/2022 9:00:03 AM(UTC)
