llano339
#1 Posted : Wednesday, November 3, 2010 3:57:46 PM(UTC)
llano339
runs fine for about 10 min then turns off and wont allow restarting for 1 hr
kayakcrzy
#2 Posted : Thursday, November 4, 2010 3:39:15 AM(UTC)
kayakcrzy
That sounds like the motor is getting hot, and shutting off on heat overload. Try running it by taking off the vent hose at the wall and leaving the vent hose attached to the dryer, and put a panty hose around the end of the vent hose that goes on the wall, so you can catch the lint. If it works fin e, then you either have a clogged vent to the outside, or there could be a big build-up of lint inside the dryer. So if you pop the top up, and take the front off, down below is the vent housing, that is where that dryer builds up lint. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
#3 Posted : Thursday, November 4, 2010 4:05:16 AM(UTC)
I would also check that the drum rotates by hand fairly easily, could be excessive drag on the motor is causing it to overheat.
You may want to try this on a couple other units to get a feel for it.
Also does it shut down if you run it just on air fluff (no heat)?
The reason I ask is I just had a person whose unit had a bad seal at the blower housing and it was blowing hot air back at the motor causing it to overheat.
Gas Dryer turns off early (Dryer Repair)
by giorfido 12/31/2022 8:36:38 AM(UTC)
Dryer Turns off in less than 30 seconds. (Dryer Repair)
by GalyonGal 4/7/2018 2:56:42 PM(UTC)
Whirlpool dryer turns off when using high heat (Dryer Repair)
by SheepNutz 6/24/2017 8:00:00 PM(UTC)
Dryer turns off (Dryer Repair)
by lmkot 3/5/2017 9:39:46 PM(UTC)
Dryer turns off mid cycle and then turns itself back on (Dryer Repair)
by acosto04 12/24/2012 1:19:34 PM(UTC)
dryer turns off after few minutes (Dryer Repair)
by jpstep 6/19/2012 12:33:45 PM(UTC)
Whirlpool Dryer turns off (Dryer Repair)
by AHESCOBEDO75 8/25/2011 5:23:26 PM(UTC)
Dryer turns off after 10 min (Dryer Repair)
by clarence ray 12/31/2010 2:26:48 PM(UTC)
Dryer turns off after a few seconds (Dryer Repair)
by Tanzee 12/15/2010 1:32:13 PM(UTC)
Dryer turns off autmatically in TIMED mode but not the others, delicate, cotton etc. (Dryer Repair)
by Rawbert 1/15/2010 3:15:58 PM(UTC)
dryer turns off and won,t restart for about an hour (Dryer Repair)
by captainda 12/6/2009 5:48:35 AM(UTC)
by Jarhead72 6/27/2009 7:28:56 AM(UTC)
dryer turns off before cycle complete (Dryer Repair)
by AmyC 5/1/2009 1:24:09 PM(UTC)
gas dryer turns off(timer runs) re starts on own?? (Dryer Repair)
by efniatet 12/7/2008 6:21:27 PM(UTC)
