I have the loud noise, the verticle tub movement and brown grease splatter in the rear of the washer, is there a bearing replacement kit for the outer tub for this older model Thanks, Tony.
Groups: Expert
Originally Posted by: tonywh  I have the loud noise, the verticle tub movement and brown grease splatter in the rear of the washer, is there a bearing replacement kit for the outer tub for this older model Thanks, Tony. The last time I did one of these it took a part AP4028180 to fix it. I have heard of people removing the rear bearing and pressing in new ones, but I've never done it myself. It would be a fairly complicated job and I have no idea how durable the repair would be.
Originally Posted by: ThatGuy  The last time I did one of these it took a part AP4028180 to fix it.
I have heard of people removing the rear bearing and pressing in new ones, but I've never done it myself. It would be a fairly complicated job and I have no idea how durable the repair would be. Thank you "thatguy" for the comments & part #, I will comment back when I have compleated bearing rebuild, Tony wh
Originally Posted by: tonywh  Thank you "thatguy" for the comments & part #, I will comment back when I have compleated bearing rebuild, Tony wh UPDATE, I finished the repair, it was a lot of work, but we have a machine that operates quietly, the kit & tool rental cost me $168.00 vs the $568.00 outertub cost that would also be about the same amount of work. Regards, Tonywh.:)
Groups: Expert
Originally Posted by: tonywh  UPDATE, I finished the repair, it was a lot of work, but we have a machine that operates quietly, the kit & tool rental cost me $168.00 vs the $568.00 outertub cost that would also be about the same amount of work. Regards, Tonywh.:) Cool! I'm glad to hear there is another way to repair these. Usually when I tell a customer how much its going to cost to repair, they decide to buy a new one.
Originally Posted by: ThatGuy  Cool! I'm glad to hear there is another way to repair these. Usually when I tell a customer how much its going to cost to repair, they decide to buy a new one. Hello Thatguy, Thank you for your comments, the source for the bearings & tool kit rental is NEPTUNE BEARING REPLACEMENT & TONY TOOL RENTAL)
