chavens50
#1 Posted : Wednesday, November 3, 2010 11:22:34 AM(UTC)
chavens50
My fridge is not cooling however the freezer is - b/f I call a repairman - is there a manual for this model or something i can check out. Have unplugged and plugged back in - swept under the grille. Thanks!
Joe / APP Team
#2 Posted : Wednesday, November 3, 2010 3:39:43 PM(UTC)
Joe / APP Team
Chavens,
Sounds like a defrost problem,
If you look at the rear wall of the freezer compartment, does it have frost or ice on the wall ?
Do you have a multi meter , so you can check the defrost heater and thermostat circuits ?
The Tech data sheet and wiring diagram should be in a plastic envelope behind the kick plate grille on the unit , if it's there you can perform several operation modes and diagnostic read outs from there.
Guest (4)
