AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
freezer cool, fridge not Kenmoore 596.75502400 - bottom freezer
My fridge is not cooling however the freezer is - b/f I call a repairman - is there a manual for this model or something i can check out. Have unplugged and plugged back in - swept under the grille. Thanks!
Originally Posted by: chavens50  My fridge is not cooling however the freezer is - b/f I call a repairman - is there a manual for this model or something i can check out. Have unplugged and plugged back in - swept under the grille. Thanks! Chavens, Sounds like a defrost problem, If you look at the rear wall of the freezer compartment, does it have frost or ice on the wall ? Do you have a multi meter , so you can check the defrost heater and thermostat circuits ? The Tech data sheet and wiring diagram should be in a plastic envelope behind the kick plate grille on the unit , if it's there you can perform several operation modes and diagnostic read outs from there. :) :) :)
