The sanitized clean light is flashing and turning off power and trying to reset does not solve the problem.
Originally Posted by: terrysater@att.net  The sanitized clean light is flashing and turning off power and trying to reset does not solve the problem. Terry, How many times does the light flash, before it pauses ( should be seven times then pause and repeat) if you have a heater circuit problem. A steady flash would indicate a bad key on the control panel. If you remove the lower kickplate from the front of the dishwasher, you should find the Tech Data Sheet and can run all the test modes and diagnostics. Good Luck, :) :) :)
