I was using the self-cleaning for about an hour and 1/2. It was off for about 45 minutes, and I used a rag (not cold, room temp.) to clean some stuff on the interior glass of the oven door and suddenly watched it crack gradually:eek: The warranty of course ran out!:( My husband wants to order and replace the part himself. :D Is this safe? :confused: The companies want over $200, closer to 3 to replace it. :cool: They said it's very risky for others to replace it.
What do you suggest? :o Thank you for taking my question. Liz
The part number for the inner door is AP2126630 less than $62 and it's not risky, just have to be careful not to chip the glass when putting it in. This site doesn't have the picture breakdown but if needed I can post them for you. Nat
I would love the picture breakdown......my husband is doing this! Thanks sooo much, Liz
Here's the exploded view of the door. And here's your parts list Model PLGF389CCB Nat libertyappl attached the following image(s):
Could you kindly let me know the number of the item I am replacing? On the diagram, it's a little hard to tell! I did not know there would be so many parts! Thanks so much, Liz
I know you left me an order number, but I mean a number on the diagram. Thank you, Liz
The part number I listed above is number 16 on the picture.
Nat
