jensen54149
#1 Posted : Monday, November 1, 2010 5:20:36 PM(UTC)
jensen54149
My Ice maker stopped working. I am thinking it is a problem with the water valve. Part # 2205762 has quick connect water line fittings. My frig has screw on type connections. What must be done to make this work?
#2 Posted : Monday, November 1, 2010 7:05:31 PM(UTC)
Using a sharp knife cut off the plastic tubes close to the old valve and push them into the the new valve connectors.
