My Ice maker stopped working. I am thinking it is a problem with the water valve. Part # 2205762 has quick connect water line fittings. My frig has screw on type connections. What must be done to make this work?
Using a sharp knife cut off the plastic tubes close to the old valve and push them into the the new valve connectors.
