marybalk
#1 Posted : Saturday, October 30, 2010 4:56:55 PM(UTC)
marybalk
Cold air is leaking out around the doors of my Magic Chef refrigerator. Where can I get replacement seals for the doors?
Thank you.
#2 Posted : Sunday, October 31, 2010 2:28:00 AM(UTC)
A model number may help others help you.
Sometimes the hinge side of the seal can gram onto the units frame and cause a poor seal. A common fix for this is a light coating of white lithium grease or vaseline along that side.
Many units have a plastic cam assembly as part of the lower door hinge. This helps keep the door closed. Check that yours are OK.
