Cold air is leaking out around the doors of my Magic Chef refrigerator. Where can I get replacement seals for the doors? Thank you.
A model number may help others help you.
Sometimes the hinge side of the seal can gram onto the units frame and cause a poor seal. A common fix for this is a light coating of white lithium grease or vaseline along that side.
Many units have a plastic cam assembly as part of the lower door hinge. This helps keep the door closed. Check that yours are OK. |
THIS FORUM IS DEAD!!!!!!! |
