lindadeluca
#1 Posted : Tuesday, October 28, 2008 3:20:40 AM(UTC)
lindadeluca
My last load of laundry yesterday left a bit of water in the tub. I ran the "drain/spin" cycle again and pulled the clothes out. I left the door open, the machine was OFF and yet came home last night to a laundry room full of water. I closed the door, ran the "drain/spin" cycle again and this morning there is still water in the tub - and had the door been open, I would have had another flood!
Help!!!
kayakcrzy
#2 Posted : Tuesday, October 28, 2008 4:22:54 AM(UTC)
kayakcrzy
If you had water in the tub with the washer off, you need to replace the water valve. You have to take the top off to do it. Unplug the washer, and there are three screws in the back, that you would take off to remove the top, and then you can easily get to the valve from there. I would also take the bottom panel off the front, there are three screws on the very bottom of the panel, to take off, and then once it is off, and there is no water in the tub, right up front in the middle on the bottom, is the pump and filter. Turn the big pastic cover, and clean out the filter while your at it. Tom ApplianceEducator.com
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
LTF2940FE0 FRIGIDAIRE FRONT LOAD WASHER (Washer Repair)
by Guest 9/8/2022 9:06:55 PM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
fRIDGIDAIRE AFFINITY FRONT LOAD WASHER WILL NOT STAY IN LOCK MODE (Washer Repair)
by Guest 2/21/2022 3:21:13 PM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Samsung front load washer rotor cover hitting (Washer Repair)
by Kickerjb44 12/19/2021 3:31:57 PM(UTC)
Samsung Front Load Washer Gets Stuck at 1 Minute (Washer Repair)
by Radar314 11/12/2021 5:45:08 AM(UTC)
maytag 2000 front load washer (Washer Repair)
by crazyeyebrad 10/30/2021 7:34:44 AM(UTC)
WF56H9100AG/A2 Samsung Front Load Washer Displays 4e / LE error code (Washer Repair)
by dcgtechnologies 10/1/2021 9:38:54 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
