I Press knob in and turn to select point on dial to Start-Pull knob out and it starts-runs for a minute or two and then shuts off. I push knob in and then out again and machine immediately starts. This happens serveral times during the cycle. Baisically, after starting cycle, the washer shuts off and requires several pushing in and pulling out of knob to complete the cycle. I replaced the timer and the same problem is still present. Would appreciate you input. SJLandau
you may have a motor problem
