hello unit display error mesage freezer E and refrigerator F. I notice evaporator fan (part # udqt36el3) not workinng took it out check the resistant on brown and red wires its 1800 the other 2 wire dont show any. check the harnest for for power on all lead dont show any. I took the board switch terminal out check the fuse continuity okay what else do I need to do to rule out boardf switch.part #240596301 or 241511101. When unit is plug in compressor start unit works for abaout 5 seconds the evaporator fan never turns on then shots off and display error mesage. 2 years ago unit board switch terminal was change unit was under warranty if you think its the board again can you tell me why they go bad. Please how can i check to be absolutly clear that i going to order the right part.
thankyou for your time and god bless you
RAUL
Originally Posted by: raulcooling  hello unit display error mesage freezer E and refrigerator F. I notice evaporator fan (part # udqt36el3) not workinng took it out check the resistant on brown and red wires its 1800 the other 2 wire dont show any. check the harnest for for power on all lead dont show any. I took the board switch terminal out check the fuse continuity okay what else do I need to do to rule out boardf switch.part #240596301 or 241511101. When unit is plug in compressor start unit works for abaout 5 seconds the evaporator fan never turns on then shots off and display error mesage. 2 years ago unit board switch terminal was change unit was under warranty if you think its the board again can you tell me why they go bad. Please how can i check to be absolutly clear that i going to order the right part.
RAUL Model number is wrong. Comes up for a Microwave. :confused:
RAUL hello icehouse i been trying to look all over the refrigerator i can not find a different model # except for the one i provided the only thing i can tell you is the label said electrolux but the unit outside logo said frigidaire. I can search for parts but can not find the model using this model # so i know what you talking abaout. What can i do to help the only information that i can give is a side by side refrigerator model # fsc23rdw5 Serial # 1a52025040 the 2 parts i seach for are part # 241511101 and udqt36el3. let me know what else i can do to help. raul
FSC23R5DW5
could this be your model number? If so and you want to see a parts breakdown go to searspartsdirect and type in this model number. Nat
yes thats the one i try to download the manual but it did not want to take my email to register. can you tell me how to troble shoot this board switch terminal and the fan now. Please help my wife is driving me crazy with guilt.
Originally Posted by: raulcooling  yes thats the one i try to download the manual but it did not want to take my email to register. can you tell me how to troble shoot this board switch terminal and the fan now. Please help my wife is driving me crazy with guilt. http://www.applianceaid.com/adaptive_defrost.html
ice house did you forget me!!!!!!!!!!!!!
raul
Originally Posted by: raulcooling  ice house did you forget me!!!!!!!!!!!!!
raul :confused: I posted a link that explains adaptive defrost and how to troubleshoot. :rolleyes:
