My frig is freezing on the top shelves and under the veggie crispers.:(
Fact: The refrigerator is cooled by airflow from the freezer through a vent with either a vent control (opens and closes manually) or a damper control (opens and closes automatically by sensing temperature). If the latter, change the damper control. As far as under the crispers check for a blocked drain. :)
