AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Wash Cycle Slow, Wont Spin,But water is pumped out
during wash cycle it agitates very slow, when it reaches spin cycle, agitator stops, but water is expelled from hose..timer was replaced 4yrs ago to correct a no spin no water eject problem and has worked flawlessly until now...
Well if this here washer pumps out then the lid switch is ok, I would be willing to bet you have a bad belt. It is easy to replace IF you remove the motor and pump assembly from the washer and replace the belt then re- install that assembly. The pump needs stardrive screwdriver by the way and I THINK you remove 4 bolts to get that motor and pump assembly out after removing the front panel. The motor has a quick plug so no wiring to worry about. Make a note of how that belt goes between the pump. If ye ferget then ye will cuss.:D
Washer Repair
