dzentkovic001
#1 Posted : Monday, October 25, 2010 5:53:04 AM(UTC)
dzentkovic001
I have a Frigidaire electric double oven Model PLEB30T8CCB where the top oven bake element will not heat (the broil element works fine). We have tested out the bake element which works fine - however one leg of the power feeds to the bake element does not have 120vac. In trying to trace back to the next component in the line - we are unable to determine if the lack of power is due to the clock/control or some rely board on the top of the oven. Any ideas on how to isolate this or what the problem may be?
thanks
magician59
#2 Posted : Monday, October 25, 2010 6:00:30 AM(UTC)
magician59
I would suspect this relay board.
Part number: AP2127301
dzentkovic001
#3 Posted : Monday, October 25, 2010 9:49:46 AM(UTC)
dzentkovic001
Thanks Magician - To clarify your response - I have a double electric oven and it appears there are two relay boards on the top of the oven. One appears to have a transformer and the other does not - Do know which of the two would need to be replaced? Again it is the upper oven where the bake element is not working. thanks
bake element will not heat up (Oven Repair (including Ranges and Cooktops))
by aljoe 3/20/2010 8:28:11 AM(UTC)
Maytag Bake Element will not heat up (Oven Repair (including Ranges and Cooktops))
by Derswick 10/12/2009 2:26:52 PM(UTC)
bake element will not heat (Oven Repair (including Ranges and Cooktops))
by pdqhale 6/23/2009 7:36:26 AM(UTC)
Oven Bake Element will not heat up (Oven Repair (including Ranges and Cooktops))
by wcwilson1 4/16/2009 5:13:18 AM(UTC)
Bake element will not heat (Oven Repair (including Ranges and Cooktops))
by djmikey9 4/15/2009 6:05:15 PM(UTC)
