I have a Frigidaire electric double oven Model PLEB30T8CCB where the top oven bake element will not heat (the broil element works fine). We have tested out the bake element which works fine - however one leg of the power feeds to the bake element does not have 120vac. In trying to trace back to the next component in the line - we are unable to determine if the lack of power is due to the clock/control or some rely board on the top of the oven. Any ideas on how to isolate this or what the problem may be?
thanks
Originally Posted by: magician59 Thanks Magician - To clarify your response - I have a double electric oven and it appears there are two relay boards on the top of the oven. One appears to have a transformer and the other does not - Do know which of the two would need to be replaced? Again it is the upper oven where the bake element is not working. thanks
