Heard a grinding/rattling sound coming from washer. Drum did not drain in rinse cycle. I took the pump apart and found that the prop fell off the pump shaft. I reassembled it and ran it thru a cycle. Washer drained in the wash and first rinse cycle but did not drain after that. I removed the pump again and it was very hot. I am figuring this is probably the pump so I ordered one today. Do you think that it might be the pump?
Thank you very much
Sounds like the pump to me. Nat
