Ronjg
#1 Posted : Friday, October 22, 2010 9:23:45 AM(UTC)
Ronjg
This washer is a real workhorse. Have never had it serviced. I believe it is at least 20 years old. Everything is still working fine but the clothes have gradually been getting dry less and less. I inspected the belts. They appears dry rotted and there is little tension. Pump is working however I did notice some risidual water in the tub when I turned it on its back. Please give me you thoughts.
#2 Posted : Friday, October 22, 2010 12:49:33 PM(UTC)
Very likely the problem is a bad pump belt. Nothing last forever. :)
Replace both belts and adjust them as described in the attached instructions.
- The belts kit Part number: AP4011179
Here are the breakdown diagrams and Replacement parts for MAYTAG LAT8214AAE Washer - Top Loading | AppliancePartsPros.com
File Attachment(s):
Pump belt adjustment.doc (51kb) downloaded 2 time(s).
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
clothes not drying (Dryer Repair)
by wu5062@cox.net 8/31/2013 8:27:35 AM(UTC)
Clothes not drying (Dryer Repair)
by dlw918 7/3/2012 9:24:41 AM(UTC)
Dry has heat but clothes not drying (Dryer Repair)
by spayonk 1/17/2012 8:29:42 AM(UTC)
dryer heats intermittently,clothes not drying properly (Dryer Repair)
by keithblake@peoplepc.com 3/12/2011 10:23:53 AM(UTC)
by TJFox15 1/22/2011 12:34:30 PM(UTC)
Clothes not drying compleatly (Dryer Repair)
by Marc Anderson 11/29/2010 4:32:45 PM(UTC)
Clothes not dry (Dryer Repair)
by priceclover1 1/26/2010 3:17:01 PM(UTC)
Clothes not drying complete.....GE dryer (Dryer Repair)
by FDAR 8/14/2009 3:25:07 PM(UTC)
Maytag dryer turns and heats but clothes not dry (Dryer Repair)
by ldhaynes 2/16/2009 7:21:02 AM(UTC)
by tedward77 11/16/2008 6:47:50 AM(UTC)
Top of Dryer hot but clothes not drying (Dryer Repair)
by sween 10/27/2007 10:32:22 AM(UTC)
