priceclover1
#1 Posted : Tuesday, January 26, 2010 3:17:01 PM(UTC)
priceclover1
Dryer heats up in a normal cycle, clothes are not totally dry.
oilslinger53
#2 Posted : Tuesday, January 26, 2010 4:43:48 PM(UTC)
oilslinger53
Sounds like the vent is obstructed. It could be the coils on the valve too. When they fail it usually work for up to 5-15 ignitions, then go cold.
priceclover1
#3 Posted : Wednesday, January 27, 2010 1:59:30 PM(UTC)
priceclover1
The vent is not clogged.
Can you replace the coils and not the valve?
Is there a way that you can tell if the valve or the coils are not working, how can you tell which one is not working.
Should I order 2 coils or the valve with 2 coils?
Can you briefly explain what you mean about the 5-15 ignitions?
Looking forward to hearing from you.
Thank you for your help so far.
Dave Price
oilslinger53
#4 Posted : Thursday, January 28, 2010 5:29:22 PM(UTC)
oilslinger53
The coils come in a set of two, and are available from a few manufacturers. One part number is 5303931775. Thats a frigidaire number, but the coils are all the same. What I mean by 5-10 ignitiong is that the burner cycles on, and off 30-40 times in a drying cycle. Each time it comes on, the igniter comes on, then the coils open the gas valve. When you first start the dryer it may get hot, but then after a few minutes it will stop heating. It will still run, just wont heat. It could also have a bad blower wheel, but that will usually make a rumbling sound when the dryer stops and starts.
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
clothes not drying (Dryer Repair)
by wu5062@cox.net 8/31/2013 8:27:35 AM(UTC)
Clothes not drying (Dryer Repair)
by dlw918 7/3/2012 9:24:41 AM(UTC)
Dry has heat but clothes not drying (Dryer Repair)
by spayonk 1/17/2012 8:29:42 AM(UTC)
dryer heats intermittently,clothes not drying properly (Dryer Repair)
by keithblake@peoplepc.com 3/12/2011 10:23:53 AM(UTC)
by TJFox15 1/22/2011 12:34:30 PM(UTC)
Clothes not drying compleatly (Dryer Repair)
by Marc Anderson 11/29/2010 4:32:45 PM(UTC)
Clothes Not Dry (Washer Repair)
by Ronjg 10/22/2010 9:23:45 AM(UTC)
Clothes not drying complete.....GE dryer (Dryer Repair)
by FDAR 8/14/2009 3:25:07 PM(UTC)
Maytag dryer turns and heats but clothes not dry (Dryer Repair)
by ldhaynes 2/16/2009 7:21:02 AM(UTC)
by tedward77 11/16/2008 6:47:50 AM(UTC)
Top of Dryer hot but clothes not drying (Dryer Repair)
by sween 10/27/2007 10:32:22 AM(UTC)
