2 Pages<12
lucille789
#11 Posted : Thursday, October 30, 2008 11:17:05 AM(UTC)
lucille789
I have tested my oven with a temp gauge and when I set it for 375 the oven only gets about 125. When I set to 550, it gets to 240. As I said, this was a used oven that is probably over 10 years old. I don't want to start replacing sensors, elements, and other parts only to find out it is probably the control board. Can anyone tell me for sure the direct cause of this problem??
v2k04
#12 Posted : Thursday, October 30, 2008 12:27:00 PM(UTC)
v2k04
Well if the elements are good and the sensor ohms out good that only leaves one thing that isn't good the board. Time for a new stove
oven does not heat to correct temp (Oven Repair (including Ranges and Cooktops))
by wawpooh 3/8/2011 11:54:18 AM(UTC)
2 Pages<12
