My maytag washer loses power completely, usually when the tub is full, the plug is fine, no breakers tripped. Doesn't fill , spin, nothing in any cycle, it has a finger faucet to manually turn on the water, it doesn't even work. I pushed the control knob in to turn it off,(even though it was already off). After about 30 minutes I hear a little click and everything is working fine.It went through the whole cycle with no problems. What could be causing this to happen?? Thanks for any help..
Did it do this on a 2nd load right after doing the 1st load? Nat
No, It was the only time I had used it all day. Thanks.
