marshmallow
#1 Posted : Wednesday, October 22, 2008 7:38:35 PM(UTC)
marshmallow
My maytag washer loses power completely, usually when the tub is full, the plug is fine, no breakers tripped. Doesn't fill , spin, nothing in any cycle, it has a finger faucet to manually turn on the water, it doesn't even work.
I pushed the control knob in to turn it off,(even though it was already off).
After about 30 minutes I hear a little click and everything is working fine.It went through the whole cycle with no problems.
What could be causing this to happen?? Thanks for any help..
libertyappl
#2 Posted : Wednesday, October 22, 2008 8:01:03 PM(UTC)
libertyappl
Did it do this on a 2nd load right after doing the 1st load?
Nat
marshmallow
#3 Posted : Thursday, October 23, 2008 6:18:59 AM(UTC)
marshmallow
No, It was the only time I had used it all day. Thanks.
no power to maytag washer (Washer Repair)
by jleach 8/3/2010 1:30:50 PM(UTC)
