we have an amana NAV8805Eww washer, about 1 year old we had a power issue yesterday, a wire came down and was partially detached causing our home to be on minimal power for a short time, it appears to have effected the electronics on our washer. the lights around the setting dial keep all flashing. When I start the washer it runs for about a minute, then all the lights flash again and it stops. any ideas?
Perform the troubleshooting as described in the tech sheets. Post the results. Gene.
