We have a Amana washer is leaking from seal around inside shift, I posted 2 pics here, removed agitator, but, don't know how to remove seal from the shaft. There's a loose washer, then a fixed black washer, then the rubber boot. How do I finish taking this apart ? Thanks ! Jim djim attached the following image(s):
look on this site how to replace main bearing there is a video of the tear down i'm having basically the same problem with my amana
