Carlos1787
#1 Posted : Thursday, October 21, 2010 8:13:23 AM(UTC)
Carlos1787
I have 2 problems with my gas range. the oven doesn't seem to hold it's temp properly and when I set the unit to the Broil position, the oven burner turns on. After a short while the preheated light comes on and the oven burner turns off. the broiler burner never turns on and the igniter for the broiler doesn't turn on either.
I am guessing that the only thing that could cause this behavior would be a bad control panel. What should I check before replacing such an expensive part?
full model number arg7102w p1143347n w
magician59
#2 Posted : Thursday, October 21, 2010 10:13:27 AM(UTC)
magician59
It could be a bad broiler igniter. Part number: AP2934763
Carlos1787
#3 Posted : Thursday, October 21, 2010 11:06:21 AM(UTC)
Carlos1787
Really? a bad broiler igniter could cause the lower oven burner to turn on instead?
magician59
#4 Posted : Thursday, October 21, 2010 11:25:28 AM(UTC)
magician59
While the oven preheats, BOTH burners are activated. This makes for shorter preheat times.
