My Maytag neptune washer has power going to it, however when I select a function lights come on, door locks and nothing happens. I can hear the machine calling for water(clicking noises) but no water going into washer. I call for spin only, hear clicking noises nothing happens. please help.
It sounds like you may have a problen with one of the control boards. Inside your console you should find a tech sheet that will lead you through a diagnostic program. Do this and you should have fault codes that you can use to diagnose the problem. Let us know what you find.
Originally Posted by: magician59  It sounds like you may have a problen with one of the control boards. Inside your console you should find a tech sheet that will lead you through a diagnostic program. Do this and you should have fault codes that you can use to diagnose the problem. Let us know what you find. Thank you, I'll give that a try. Joe
Originally Posted by: magician59  It sounds like you may have a problen with one of the control boards. Inside your console you should find a tech sheet that will lead you through a diagnostic program. Do this and you should have fault codes that you can use to diagnose the problem. Let us know what you find. thank you very much
