MLL
#1 Posted : Tuesday, October 21, 2008 9:39:09 AM(UTC)
MLL
My magtag washer will not go through the cycles. It will fill with water but then stops. The first time it did this I smelled burning wire. Now the control knob for the cycle just spins and no longer clicks.
Has the timer burned out?
How do I remove the conrtol knobs and get the panel off to check?
v2k04
#2 Posted : Tuesday, October 21, 2008 9:49:39 AM(UTC)
v2k04
If your just checking for a broken knob you have to get in the control panel by removing the back panel. On the timer you'll see a plastic stem you have to hold that with needle nose while you pull the knob off there are also instuctions printed on the timer how to remove knob.
removing control knob on washer (Washer Repair)
by Jme1408 7/27/2013 8:51:53 PM(UTC)
