anewman
#1 Posted : Monday, October 18, 2010 3:23:51 PM(UTC)
anewman
i am going to replace the motor in my dryer, but my dad needs to know how to to ge the fan blade off to get to the motor. or do i have to buy a new fan blade also
#2 Posted : Tuesday, October 19, 2010 3:40:28 AM(UTC)
I cannot find any info on the given model number so the below is a bit of guessing.
Many Admirals use a screw on blower wheel.
Note: That it is usually a left hand thread.
It is not uncommon for it to seize onto the motor's shaft and the only way to remove it is to break it.
http://www.applianceaid.com/wpmotor-change.html
There are also other blower wheel attachment methods CIR clip etc.
Perhaps you will be able to find yours in the following.
http://www.applianceaid.com/dryers.html
