i am going to replace the motor in my dryer, but my dad needs to know how to to ge the fan blade off to get to the motor. or do i have to buy a new fan blade also
I cannot find any info on the given model number so the below is a bit of guessing. Many Admirals use a screw on blower wheel. Note: That it is usually a left hand thread. It is not uncommon for it to seize onto the motor's shaft and the only way to remove it is to break it. http://www.applianceaid.com/wpmotor-change.htmlThere are also other blower wheel attachment methods CIR clip etc. Perhaps you will be able to find yours in the following. http://www.applianceaid.com/dryers.html |
THIS FORUM IS DEAD!!!!!!! |
