klipshc
#1 Posted : Monday, October 20, 2008 2:35:05 PM(UTC)
klipshc
I have a whirlpool LGN2000LW0 that will ignite and heat up for about 3 minutes then the flame goes out and wont ignite no more. You have to wait about 10 min and then the flame will ignite again. I have looked thru the post and seen others with similiar issues. Most seem to be problems with the coils, Could this be the most likely cause of this.
#2 Posted : Monday, October 20, 2008 6:06:36 PM(UTC)
Most likely the problem are a bad coils.
- The part number for the Whirlpool coil kit is AP3094251
This part is on backorder but you can use the same kit from Frigidaire. They are absolutely identical.
- The part number for the Frigidaire coil kit is AP2150379
Here are the break down diagrams for the Whirlpool dryer Model LGN2000LW0
