I have a whirlpool LGN2000LW0 that will ignite and heat up for about 3 minutes then the flame goes out and wont ignite no more. You have to wait about 10 min and then the flame will ignite again. I have looked thru the post and seen others with similiar issues. Most seem to be problems with the coils, Could this be the most likely cause of this.
Most likely the problem are a bad coils. - The part number for the Whirlpool coil kit is AP3094251 This part is on backorder but you can use the same kit from Frigidaire. They are absolutely identical. - The part number for the Frigidaire coil kit is AP2150379Here are the break down diagrams for the Whirlpool dryer Model LGN2000LW0Gene.
