nhss60532
#1 Posted : Sunday, October 17, 2010 10:22:36 PM(UTC)
nhss60532
I need to replace either drum roller or the bearing for Maytag gas dryer. I'm stuck with the top panel to access the drum. I could not find a diagram to open it. I removed 3 screws from the back, and it can be lifted few inches. But pulling it backward to open it not working. Can some one please help.
Thanx
kayakcrzy
#2 Posted : Monday, October 18, 2010 3:08:43 PM(UTC)
kayakcrzy
Thanx
I believe on this one you take the 2 screws that hold the bottom front panel on. Once you remove the panel on the bottom side of the front will be 2 screws on each side. Remove them, and then pull the bottom of the front panel towards you, and at a 45 degree and the top will drop out. Then you have to remove the blower assembly, by removing 4 screws 2 on each side. The remove the belt, and then pull the drum out. I bet the idler pully well is bad. But since you are in there, replace the rollers too. The parts are not that all expensive. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
