The repair man said we need part # 74009559 replaced in our Wall Oven because it is not holding the set temperature. If set at 350 degrees...it gets up to 420 degrees. I found this part # on your web site....is this what I need for heat regulation? Please help me asap so I can get my oven running again! Thanks
How did the repairman come to that diagnosis? Did he test the temperature sensor? The part number you posted is the clock/control. Here's a replacement part. Part number: AP4097861
