sedans2
#1 Posted : Friday, October 15, 2010 10:25:30 AM(UTC)
sedans2
The repair man said we need part # 74009559 replaced in our Wall Oven because it is not holding the set temperature. If set at 350 degrees...it gets up to 420 degrees. I found this part # on your web site....is this what I need for heat regulation? Please help me asap so I can get my oven running again! Thanks
magician59
#2 Posted : Friday, October 15, 2010 11:01:29 AM(UTC)
magician59
How did the repairman come to that diagnosis? Did he test the temperature sensor? The part number you posted is the clock/control. Here's a replacement part.Part number: AP4097861
