Sgt.D
#1 Posted : Friday, October 17, 2008 6:38:32 PM(UTC)
Sgt.D
Just 4 days ago, our dyer wont dry at all. I started to clean the lint stored in the dryer in front & back and it started with normal heat but suddenly disappear after the normal cycle. Sounds familiar? Please advise...thank you
libertyappl
#2 Posted : Friday, October 17, 2008 6:53:38 PM(UTC)
libertyappl
Test the cycling thermostats for continuity, make sure they test out.
Nat
SublimeMasterJW
#3 Posted : Friday, October 17, 2008 9:10:20 PM(UTC)
SublimeMasterJW
The blower wheel on these dryers
is plastic and will tend to get loose on the shaft
and cause the dryer to be very in efficient.
SublimeMasterJW attached the following image(s):
Sgt.D
#4 Posted : Saturday, October 18, 2008 6:47:04 PM(UTC)
Sgt.D
do you have step by step procedure to find this blower, hope you dont mind. I just really a rookie on this dyer. Thanks in advance.
Sgt.D
#5 Posted : Saturday, October 18, 2008 6:52:33 PM(UTC)
Sgt.D
I have open the top of the dryer and have not seen where the thermostat is..any idea? The model of my dyer is SDG305DAWW with SN#1743667EV with that help? If you dont mind can you tell step by step procedure to find this out and to pull out this thermostat. I really appreciate your help.
libertyappl
#6 Posted : Saturday, October 18, 2008 7:16:34 PM(UTC)
libertyappl
Remove the rear panel of the dryer, the thermostats are located where the wires connect. There are a few of them. the blower wheel is inside the housing connected to where the exhaust is.
This isn't your exact model but it's pretty close. Click on this link and you can see a breakdown on the unit. Model SDG4000AWW
Nat
Dyer Problem (Dryer Repair)
by Jeannine Medlin 11/10/2010 8:48:29 AM(UTC)
