Hello, From the partition between the top freezer and bottom frig is a port. From that port there is water dripping. Could it be a possible drain line clog to the compressor drip pan or if you could direct me to a possible part. Thank you.
Originally Posted by: hiwata  Hello, From the partition between the top freezer and bottom frig is a port. From that port there is water dripping. Could it be a possible drain line clog to the compressor drip pan or if you could direct me to a possible part. Thank you. Hiwata, That would be a good place to start, Are you sure the doors are sealing correctly ? Is there frost or ice on the freezer back wall ? You'll need to remove the back wall in the freezer to check for a clogged or frozen drain hole / tube, so you can check it then. :) :) :)
