hiwata
#1 Posted : Thursday, October 14, 2010 11:58:58 AM(UTC)
hiwata
Hello, From the partition between the top freezer and bottom frig is a port. From that port there is water dripping. Could it be a possible drain line clog to the compressor drip pan or if you could direct me to a possible part. Thank you.
Joe / APP Team
#2 Posted : Thursday, October 14, 2010 1:25:39 PM(UTC)
Joe / APP Team
Hiwata,
That would be a good place to start,
Are you sure the doors are sealing correctly ?
Is there frost or ice on the freezer back wall ?
You'll need to remove the back wall in the freezer to check for a clogged or frozen drain hole / tube, so you can check it then.
